Model.autotopocleanup#
Model.autotopocleanup(surfcollection, criteria_filename, param_filename)#
Performs automatic preparation of a model’s topology for meshing, using specified element size and element quality criteria. These criteria may include geometry feature recognition (fillets, holes, beads, flanges, etc.), the topology simplification, cleaning of small features, etc. The parameters controlling the topology cleanup stages and tools are given as a set of topology cleanup parameters.
Parameters:
  • surfcollection (Collection) – The collection containing the entities.
  • criteria_filename (hwString) – The path to the file with element quality criteria.
  • param_filename (hwString) – The path to the file with topology cleanup parameters.
Note
The quality criteria and topology cleanup parameters files should be prepared using Criteria Editor dialog from HyperMesh or BatchMesher. Both criteria and parameters set can be pre-set directly in the command file. In this case, use “dummy” for the criteria and/or parameters file name, respectively (this allows you to specify criteria/parameters directly within the following functions):
Model.readqualitycriteria() or Model.setqualitycriteria() for criteria; Model.create_batch_file(), or Model.readbatchparamsfile() for cleanup parameters.
The cleanup parameters are deleted after every call of the Model.autotopocleanup() function, so when a “dummy” parameter is used the cleanup parameters must be set with one of the above mentioned functions prior to each call of Model.autotopocleanup().
Examples#
Perform topology cleanup of all displayed surfaces use element quality criteria * C:/cleanup_files / nvh10.criteria * and quality parameters file * C:/cleanup_files / nvh10.param *#
import hm
import hm.entities as ent
model = hm.Model()
surf_col = hm.CollectionByDisplayed(model, ent.Surface)
model.autotopocleanup(
    surfcollection=surf_col,
    criteria_filename="C:/cleanup_files/nvh10.criteria",
    param_filename="C:/cleanup_files/nvh10.param",
Perform topology cleanup of all displayed surafaces use element quality criteria set directly in the command file and quality parameters file * C:/cleanup_files / nvh10.param *#
import hm
model = hm.Model()
# Setting quality criteria from command file
quality_string_list = [
    " 0 penalty value      0.00    0.00    0.80    1.00   10.00",
    " 1 min length        1 1.0   3.000   2.749   1.502   1.000   0.749  1",
    " 2 max length        1 1.0   3.000   3.600   4.500   6.000   9.000  0",
    " 3 aspect ratio      1 1.0   1.000   2.000   4.400   5.000  10.000  0",
    " 4 warpage           1 1.0   0.000   5.000  13.000  15.000  30.000  0",
    " 5 max angle quad    1 1.0  90.000 110.000 134.000 140.000 160.000  0",
    " 6 min angle quad    1 1.0  90.000  70.000  46.000  40.000  20.000  0",
    " 7 max angle tria    1 1.0  60.000  80.000 112.000 120.000 150.000  0",
    " 8 min angle tria    1 1.0  60.000  50.000  34.000  30.000  15.000  0",
    " 9 skew              1 1.0   0.000  10.000  34.000  40.000  70.000  0",
    "10 jacobian          1 1.0   1.000   0.900   0.700   0.600   0.300  0",
    "11 chordal dev       0 1.0   0.000   0.300   0.800   1.000   2.000  0",
    "12 taper             1 1.0   0.000   0.200   0.500   0.600   0.900  0",
    "13 % of trias        1 1.0   0.000   6.000  10.000  15.000  20.000  0",
model.setqualitycriteria(string_array=quality_string_list, mode=0)
# Performing clean-up operation
    criteria_filename="dummy",
