Model.collisioncheck_temp#
- Model.collisioncheck_temp(collection_int_elems=s_defaultCollection, collection_pene_elems=s_defaultCollection, collection_int_surfs=s_defaultCollection, collection_pene_surfs=s_defaultCollection, collection_pene_nodes=s_defaultCollection, self_check=0, reserved1=0, pair_angle=0.0, store_segments=1, mark_adjoining=0, topo_feature_angle=0.0, pair_results=0, flag=0, arg=0.0)#
Performs a collision detection using the input entities defined by
Model.hm_collisionentitycreate(). This must be preceded byhm_collisioninit()and one or two calls tohm_collisionentitycreate(). Multiple calls to this API can be made to perform different detections.- Parameters:
collection_int_elems (Collection) – The collection that should contain any intersected element entities on output. If collection is empty, no intersected elements are output. Valid entity types are elements or components.
collection_pene_elems (Collection) – The collection that should contain any penetrated element entities on output. If collection is empty, no penetrated elements are output. Valid entity types are elements or components.
collection_int_surfs (Collection) – The collection that should contain any intersected surfaces on output. If collection is empty, no intersected surfaces are output. Valid entity types are surfaces or solids.
collection_pene_surfs (Collection) – The collection that should contain any penetrated surfaces entities on output. If collection is empty, no penetrated surfaces are output. Valid entity types are surfaces or solids.
collection_pene_nodes (Collection) – The collection that should contain any penetrated node entities on output. If collection is empty, no penetrated nodes are output. Valid entity type is only nodes.
self_check (int) –
0 - Do not include self checks.
1 - Include self checks.
reserved1 (int) – Reserved for future use. Must be set to 0.
pair_angle (double) – The maximum allowed angle between penetrating pair normals. Meaningful values are 0.0 <
pair_angle< 90.0. Other values disable this functionality.store_segments (int) – Set to 1 to store the intersection lines formed when intersection entities. Only valid when
collection_int_elemsorcollection_int_surfsare non empty. The segments can then be visualized usingModel.createintersectionsegments(). Default is 0.mark_adjoining (int) –
0 - No additional marking (default).
1 - Mark only surrounding 2D elements. Surrounded implies all of its nodes on other penetrated elements.
2 - Mark all 2D elements on topology faces containing any penetrated elements.
3 - Mark only 2D elements sharing a node with a penetrated element and on the same topo face.
topo_feature_angle (double) – The angle used to identify topo faces. If set to 0.0, the global feature angle is utilized (default).
pair_results (int) –
If set to 0, detailed pair results are not calculated and none of the
hm_collisionget*APIs can be used (default, same asModel.hm_collisioncheck()).If set to 1, detailed pair results are calculated and the
hm_collisionget*andModel.hm_collisionwriteresultsfile()APIs can be used (same asModel.hm_collisioncheck()).If set to 2, additional collision result entities are created that can be rendered in the collision browser or used as input of other functions like
Model.collisionfix_temp()(option not available inModel.hm_collisioncheck()).If set to 3, only the collision result entities are created (for browser ,
Model.collisionfix_temp()…), but not the detailed pair results (forhm_collisionget*). This option is not available forModel.hm_collisioncheck(), and is only available for the collirad engine.Note
The
Model.hm_collisionend()does not delete any collision result entities. The deletion must be handled usingModel.deletemark().flag (int) – Reserved for future development
arg (double) – Reserved for future development
Example#
Check intersections and penetrations of components with IDs 1001 and 1002 , use the nodes of component with ID 1002 against the elements of component with ID 1001 for the penetration check , create only collision result entities#import hm import hm.entities as ent model = hm.Model() # Initial collections and output collection components_int_collection = hm.Collection(model, ent.Component, [1001]) components_pene_collection = hm.Collection(model, ent.Component, [1002]) nodes_pene_collection = hm.Collection(model, ent.Node, components_pene_collection) # Detecting the collision config status, result = model.hm_collisiongetconfig(options=["collirad"]) model.hm_collisioninit(config=result.config) model.hm_collisionentitycreate( collection=components_int_collection, dimension=0, thickness_type=1, thickness=0.0, edge_penetration=0, midside_nodes=0, split_quads=0, used_topology=0, grouping_identifier=1, offset=0 ) model.hm_collisionentitycreate( collection=components_pene_collection, dimension=0, thickness_type=1, thickness=0.0, edge_penetration=0, midside_nodes=0, split_quads=0, used_topology=0, grouping_identifier=2, offset=0 ) model.collisioncheck_temp( collection_int_elems=components_int_collection, collection_pene_elems=components_pene_collection, collection_pene_nodes=nodes_pene_collection, self_check=0, reserved1=0, pair_angle=90.0, store_segments=0, mark_adjoining=0, topo_feature_angle=0.0, pair_results=3, flag=0, arg=0.0, ) model.hm_collisionend()
