Model.createandadjustmass#
- Model.createandadjustmass(sourcecollection, targetmass, targetcogx, targetcogy, targetcogz, targetcollection=s_defaultCollection, tolerance=0.0, usestructuralmass=False, addnumericalmass=False, nodalmass=1, iterations=1, optimizetargetflag=False)#
Adjusts mass for a selection of source components by creating solvermasses on the target components.
- Parameters:
sourcecollection (Collection) – The collection containing the source component entities.
targetmass (double) – The target mass value.
targetcogx (double) – The target x-COG.
targetcogy (double) – The target y-COG.
targetcogz (double) – The target z-COG.
targetcollection (Collection) – The collection containing the target entities.
tolerance (double) – The percentage tolerance on mass to be adjusted.
usestructuralmass (bool) –
0 - Use engineering mass
1 - Use structural mass
addnumericalmass (bool) –
0 - Do not add numerical mass
1 - Add numerical mass coming from time step on the source entities
nodalmass (int) –
0 - Mass type as property mass
1 - Mass type as nodal mass
iterations (int) – Number of iterations.
optimizetargetflag (bool) –
0 - Do not use optimize target
1 - Use optimize target
Examples#
Adjust mass on all the components with specific target mass and COG values#import hm import hm.entities as ent model = hm.Model() model.createandadjustmass( sourcecollection=hm.Collection(model, ent.Component), targetmass=0.0245, targetcogx=-277.65, targetcogy=-0.49188, targetcogy=-0.49188, tolerance=10.0, usestructuralmass=True, addnumericalmass=True, )
Another example of adjusting mass on all the components with specific target mass and COG values#import hm import hm.entities as ent model = hm.Model collection_input = hm.Collection(model,ent.Component) collection_output = hm.Collection(model,ent.Component) model.createandadjustmass( sourcecollection=collection_input, targetcollection=collection_output, targetmass=16000.000000, targetcogx=24.550000, targetcogy=-16.420000, targetcogy=25.000000, tolerance=10.0, addnumericalmass=False, nodalmass=0, iterations=20, optimizetargetflag=0, )
