Model.createelementsbetweenpoints#
- Model.createelementsbetweenpoints(surf1_collection, surf2_collection, collection, tol, createplot, configval, syst, code, property)#
Creates a spotweld element between two surfaces at the marked points with an element type, coordinate system, and property ID.
- Parameters:
surf1_collection (Collection) – The collection containing the first surface entities.
surf2_collection (Collection) – The collection containing the second surface entities.
collection (Collection) – The collection containing the point entities.
tol (double) – Search tolerance to identify surfaces.
createplot (int) – Creates a plot.
configval (int) – Element type configuration value.
syst (int) –
Local coordinate system switch.
0 - Without coordinate system.
1 - With coordinate system.
code (int) –
Code for one or all surface options.
0 - All surfaces.
1 - One surface.
property (hwString) – Name of property collector.
Example#
Create spot weld ( spring elements ) between surfaces 1 and 2 , using the option individual surface within a tolerance of 0.01 at marked points with IDs 1 and 2 . Elements are created with the coordinate system and property collector “ name_prop “#import hm import hm.entities as ent model = hm.Model() surf1 = hm.Collection(model, ent.Surface, [1]) surf2 = hm.Collection(model, ent.Surface, [2]) points = hm.Collection(model, ent.Point, [1,2]) model.createelementsbetweennodes( surf1_collection=surf1, surf2_collection=surf2, collection=points, tol=0.01, createplot=1, configval=21, syst=1, code=1, property="name_prop", )
