Model.hm_ce_linkprojectionorderget_bycollection#
Model.hm_ce_linkprojectionorderget_bycollection(collection, option)#
Returns ordered projection information from links of spot connectors.
Parameters:
  • collection (Collection) – The collection containing the connector entities to query.
  • option (unsigned int) –
    0 - Return stored projection information with spot connector(s)
    1 - Redo projection for spot connector(s) and return projection information
Returns:
Example#
Get projection information from spot connector with ID 101#
import hm
import hm.entities as ent
model = hm.Model()
_, resultlist = model.hm_ce_linkprojectionorderget_bycollection(
    collection=hm.Collection(model, ent.Connector, [101]), option=1
proj_infos = resultlist.ResultList
for result in proj_infos:
    print("Connector ID:", result.connector.id)
    print("No of Layers:", result.numberOfLayers)
    for info in result.listOfLayerDetails:
        print("Layer index 1:", info.index1)
        print("Layer index 2:", info.index2)
        print("Projection Location:", info.projectionLocation)
        print("Element ID:", info.element.id)
