Model.CE_ConnectorSpotTrim#
Model.CE_ConnectorSpotTrim(collection, node_collection, tolerance, snap, mode)#
Trims/splits spot line connectors using nodes.
Parameters:
  • collection (Collection) – The collection containing the connector entities to trim/split.
  • node_collection (Collection) – The collection containing the input node entities.
  • tolerance (double) – The tolerance value used to snap the nodes to the point of spot connectors when snap=1.
  • snap (int) –
    0 - Do not snap nodes to spot connectors
    1 - Snap nodes to spot connectors
  • mode (int) –
    0 - Split
    1 - Trim
Example#
Split spot connector with ID 101 using node with ID 1001#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_ConnectorSpotTrim(
    collection=hm.Collection(model, ent.Connector, [101]),
    node_collection=hm.Collection(model, ent.Node, [1001]),
    tolerance=0.5,
    snap=1,
    mode=0,
