Model.hm_getentitycreationid#
Model.hm_getentitycreationid(entity_type, pool_id, entity)#
Returns a valid entity ID that can be used to renumber both the creating and mapping entities. If the function returns 0, it means the new entity can use any ID. If the function returns a valid ID, both the new entity and mapped entity need to be renumbered to use the returned ID.
Parameters:
  • entity_type (EntityFullType) – The entity type for the creating entity.
  • pool_id (int) – The solver ID pool number for the creating entity. A value of 0 indicates no solver ID pool.
  • entity (Entity) – The object describing the mapping entity. If None is passed, the function should find an ID for renumbering both the creating and mapping entities.
Returns:
Example#
Create a new component named “ myComp “ whose ID should map with its assigned property ID of 100#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getentitycreationid(
    entity_type=ent.Component, pool_id=0, entity=ent.Property(model, 100)
newID = result.newEntityId
myComp = ent.Component(model, name="myComp", color=5)
compID = myComp.id
if newID != 0:
    if newID != 100:
        # Renumber the property
        model.renumbersolverid(
            collection=hm.Collection(model, ent.Property, [100]),
            start_id=newID,
            incr_val=1,
            offset_val=0,
            offset_flag=0,
            reserved_1=0,
            reserved_2=0,
            reserved_3=0,
    if newID != compID:
        # Renumber the component
            collection=hm.Collection(model, ent.Component, "name=myComp"),
            start_id=newID,
            incr_val=1,
            offset_val=0,
            offset_flag=0,
            reserved_1=0,
            reserved_2=0,
            reserved_3=0,
