Model.CE_ConnectorCreateByList#
- Model.CE_ConnectorCreateByList(entitylist, ce_style, num_links, link_collection, link_elems_geom='', link_rule='', relink_rule='', tol_flag=0, tol=0, line_preserve_nodes=0, line_spacing=1.0, line_density=0, line_offset_flag=0, line_offset=0, start_offset=0.0, end_offset=0.0, retain_line=1, seam_area_group=0, ce_nonnormal=0, area_width=0.0, area_offset=0.0, area_mesh_type=0, area_mesh_size=10.0, loc_as_link=0, ce_extralinknum=0, ce_hexaoffsetcheck=0, area_linecombine=0.0, ce_normal_link=0, ce_link_option=0, ce_normal_angle=0.0, ce_center_pos=0.0, ce_boltmindiameter=0.0, ce_boltmaxdiameter=0.0, ce_boltcenterset=0, ce_num_center=0, ce_maxlinkupto=0, line_combine_option='', smooth_curve_nodes=0, ce_boltcenter=0, ce_config_name='', ce_engg_name='', ce_seam_vertex_angle=45.0, line_preserve_joints=0, ce_seam_discontinuity=0, eline_flag=False, disable_multilinks=0, grouplinks=False, main_link_count=0, main_link_ids=hwIntList())#
Creates a certain style of connector at locations specified by a list, with certain rules and details.
- Parameters:
entitylist (EntityList) – A list containing the entity objects that specify the location to create connectors. Valid entities are lines (for seam and area) and nodes (for spot, bolt, seam and area).
ce_style (hwString) – The style of connectors to create. Valid values are area, bolt, seam and spot.
num_links (int) – The number of links to use.
link_collection (Collection) – The collection containing the entities to create links for. Valid entities are components and surfaces.
link_elems_geom (hwString) – Specifies whether to connect elements (elems) or geometry (geom). Default is elems.
link_rule (hwString) – The link rule. Valid values are now, at_fe_realize or none. Default is none.
relink_rule (hwString) – The relink rule. Valid values are id, name or none. Default is none.
tol_flag (int) –
0 - Do not offset
tol(default).1 - Use
tol.tol (double) – Add entities as links only within this distance of the specified location. Default 0.0.
line_spacing (double) – The spacing for spot or seam connectors on lines. Default 1.0.
line_density (int) – The density for spot or seam connectors on lines. Default 0.0.
line_offset_flag (int) –
0 - Do not offset connectors (default).
1 - Offset connectors.
line_offset (double) – Offset value from the ends of the line for spot or seam connectors on lines. Default 0.0.
seam_area_group (int) –
Group flag for seam or area connector.
0 - No (default).
1 - Yes.
area_width (double) – Width of area connectors created from node or line lists. Default 1.0.
area_offset (double) – Offset area connectors created from node or line lists from the selected location by this value. Default 0.0.
ce_nonnormal (int) –
0 - Normal projection (Default)
1 - Non-normal projection.
retain_line (int) – Reserved for future development.
end_offset (double) – The offset distance at the end of the combined line.
start_offset (double) – The offset distance at the start of the combined line.
line_preserve_nodes (int) – Reserved for future development.
area_mesh_type (int) –
The mesh type for area connectors when type of entities in
entitylistis surfaces.0 - Trias
1 - Quads
2 - Mixed
3 - Right trias
area_mesh_size (double) – The mesh size for area connectors when type of entities in
entitylistis surfaces.loc_as_link (int) – Reserved for future development.
ce_extralinknum (int) – Reserved for future development.
ce_hexaoffsetcheck (int) – Reserved for future development.
area_linecombine (double) – Reserved for future development.
ce_normal_link (int) – Reserved for future development.
ce_link_option (int) – Reserved for future development.
ce_normal_angle (double) – Reserved for future development.
ce_center_pos (double) – Reserved for future development.
ce_boltmindiameter (double) – The minimum diameter for a hole to be accepted as a bolt hole.
ce_boltmaxdiameter (double) – The maximum diameter for a hole to be accepted as a bolt hole.
ce_boltcenterset (int) – Reserved for future development.
ce_num_center (int) – Reserved for future development.
ce_maxlinkupto (int) – Reserved for future development.
line_combine_option (hwString) –
The combine option for combining the two or more line connectors:
combine_smooth - Combines lines/connector with smooth
curvecombine_straight - Combines lines/connectors with straight
curvecombine_midline - Combines two lines/connectors as one midline connector
smooth_curve_nodes (int) – Reserved for future development.
ce_boltcenter (hwTriple) – Reserved for future development.
ce_config_name (hwString) – The name of the bolt config.
ce_engg_name (hwString) – Reserved for future development.
ce_seam_vertex_angle (double) – Reserved for future development.
line_preserve_joints (int) – Reserved for future development.
ce_seam_discontinuity (int) – Reserved for future development.
eline_flag (bool) – Reserved for future development.
disable_multilinks (int) – Reserved for future development.
grouplinks (bool) – Reserved for future development.
main_link_count (int) – Reserved for future development.
main_link_ids (hwIntList) – Reserved for future development.
Example#
Create a seam connector at the location of line with ID 10 to connect components with IDs 3 and 4 using a tolerance of 6.0#import hm import hm.entities as ent model = hm.Model() model.CE_ConnectorCreateByList( entitylist=[ent.Line(model, 10)], link_collection=hm.Collection(model, ent.Component, [3, 4]), link_elems_geom="elems", link_rule="now", relink_rule="none", tol_flag=1, tol=6.0, )
