Model.createpositionformech#
- Model.createpositionformech(name)#
Creates a new position for a mechanism. The mechanism must have the enabled flag set to true for this to be possible.
- Parameters:
name (hwString) – The name of the position to be created. If the provided name already exists, an incremental name will be used.
Example#
Translate node with ID 1 , 5.0 units along the y - axis#import hm import hm.entities as ent model = hm.Model() model.createpositionformech("newposition")
