Model.modent_saverepresentation#
Model.modent_saverepresentation(entity, options)#
Saves the contents of a modular entity representation. When entity is a subsystem entity, the saved representation will always be in HyperMesh database format (*.hm).
Parameters:
  • entity (Entity) – The object describing the modular entity to save the representation of. Valid entities are subsystems
  • options (hwString) –
    Optional list of quoted, comma separated option strings.
    • repKey=<value>
    The representation key. This is unique per subsystem.
    • filepath=<value>
    The full path and file name of the representation file.
    • repcomment=<value>
    The comment to add to the representation object.
Example#
Save the contents of subsystem with ID 1 as a representation with key “crash5” in location “C:/representations/Subsystem3_Crash5mm.hm”#
import hm
import hm.entities as ent
model = hm.Model()
model.modent_saverepresentation(
    entity=ent.Subsystem(model, 1),
    options="repKey=crash5, filepath=C:/representations/Subsystem3_Crash5mm.hm",
