Model.morphhandlepertnormal#
- Model.morphhandlepertnormal(collectionhandle, collectionelem, dist, sym, con, umark)#
Perturbs handles on collection normal to elements
- Parameters:
collectionhandle (Collection) – The collection containing the handle entities to perturb.
collectionelem (Collection) – The collection containing the element entities that tha handles should be normal to.
dist (double) – Distance of perturbation
sym (int) –
Flag to use symmetry:
0 - Do not use symmetry
1 - Use symmetry
con (int) –
Flag to use constraints:
0 - Do not use constraints
1 - Use constraints
umark (int) –
Flag to only use in the collection:
0 - Use all elements to calculate normals
1 - Use only the selected elements to calculate normals
Example#
All handles on the collection will be given a perturbation equal to dist in the normal direction as determined by either the selected elements or by all elements. If symmetry is used,all handles linked to marked handles by symmetry will also be perturbed. If constraints are used, they will be applied to the perturbations.#import hm import hm.entities as ent model = hm.Model() model.morphhandlepertnormal( collectionhandle=hm.CollectionByInteractiveSelection(model, ent.Handle), collectionelem=hm.CollectionByInteractiveSelection(model, ent.Element), dist=3.0, sym=1, con=1, umark=1, )
