Model.markprojecttomanysurfaces#
- Model.markprojecttomanysurfaces(ProjectionType, SourceEntityTypeCollection, TargetEntityTypeCollection, VectorNode1=Entity(), VectorNode2=Entity(), VectorNode3=Entity(), VectorXComp=DBL_MAX, VectorYComp=DBL_MAX, VectorZComp=DBL_MAX)#
Projects entities to multiple surfaces.
- Parameters:
ProjectionType (int) –
1 - Project by vector:
To project along a vector given its 3 components along x, y and z directions,
VectorXComp,VectorYComp, andVectorZCompare used.To project along a vector defined by 2 nodes
VectorNode1andVectorNode2are used.To project along a vector normal to the plane defined by 3 nodes
VectorNode1,VectorNode2and VectorNode3Id are used.
2 - Project normal to surfaces
SourceEntityTypeCollection (Collection) – The collection containing the entities to project. Valid entites are elements, nodes and points. This is a mandatory option.
TargetEntityTypeCollection (Collection) – The collection containing the surface entities to project onto.
VectorNode1 (Entity) – The first node entity of the vector. Valid only when
ProjectionType=1.VectorNode2 (Entity) – The second node entity of the vector. Valid only when
ProjectionType=1.VectorNode3 (Entity) – The third node entity of the vector. Valid only when
ProjectionType=1.VectorXComp (double) – The x component of the vector. Valid only when
ProjectionType=1.VectorYComp (double) – The y component of the vector. Valid only when
ProjectionType=1.VectorZComp (double) – The z component of the vector. Valid only when
ProjectionType=1.
Example#
Project nodes with IDs 1575 - 1674 to surfaces with IDs 17 - 19 along the vector ( 5.7 , 0 , 9.5 )#import hm import hm.entities as ent model = hm.Model() Elements = hm.Collection(model, ent.Element, list(range(123, 169))) Surfaces = hm.Collection(model, ent.Surface, list(range(7, 20))) model.markprojecttomanysurfaces( ProjectionType=1, SourceEntityType=Elements, TargetEntityType=Surfaces, VectorNode1=1798, VectorNode2=1820, )
Project elements with IDs 123 - 168 to surfaces with IDs 7 - 10 along the vector given by nodes with IDs 1798 and 1820#import hm import hm.entities as ent model = hm.Model() Nodes = hm.Collection(model, ent.Node, list(range(1575, 1675))) Surfaces = hm.Collection(model, ent.Surface, list(range(17, 11))) model.markprojecttomanysurfaces( ProjectionType=1, SourceEntityTypeCollection=Nodes, TargetEntityTypeCollection=Surfaces, VectorXComp=5.7, VectorYComp=0, VectorZComp=9.5, )
Project points with IDs 136 - 140 to surfaces with IDs 15 and 16 normal to the plane given by nodes with IDs 1200 , 1208 and 1210#import hm import hm.entities as ent model = hm.Model() Points = hm.Collection(model, ent.Point, list(range(136, 141))) Surfaces = hm.Collection(model, ent.Surface, [15, 16]) model.markprojecttomanysurfaces( ProjectionType=1, SourceEntityTypeCollection=Points, TargetEntityTypeCollection=Surfaces, VectorNode1=1200, VectorNode2=1208, VectorNode3Id=1210, )
Project nodes with IDs 136 - 140 normally to surfaces with IDs 15 and 16#import hm import hm.entities as ent model = hm.Model() Nodes = hm.Collection(model, ent.Node, list(range(136, 141))) Surfaces = hm.Collection(model, ent.Surface, [15, 16]) model.markprojecttomanysurfaces( ProjectionType=2, SourceEntityTypeCollection=Nodes, TargetEntityTypeCollection=Surfaces, )
