Model.CE_FE_SetDetails#
Model.CE_FE_SetDetails(collection, config, tolerance, property_id, system_flag, snap_to_node, remesh, force_collinear, fe_type)#
Set FE realization details for the connectors on a collection.
Parameters:
  • collection (Collection) – The collection containing the connector entities to update.
  • config (int) –
    Weld element type. Valid values are:
    2 - plot
    3 - weld
    5 - rigid
    21 - spring
    55 - rigidlink
    60 - bar2
    61 - rod
    70 - gap
    104 - quads
    1001 - custom
  • tolerance (double) – The maximum distance allowed between the connector and the entity in order to create welds.
  • property_id (unsigned int) – The ID of property. Used to retrieve property specified for connector.
  • system_flag (int) –
    0 - Build systems.
    1 - Do not build systems.
  • snap_to_node (int) – Force weld to use one of the element connectivity nodes rather than create a new node.
  • remesh (int) –
    Specifies if the welded area needs to be remeshed:
    0 - Do not remesh
    1 - Remesh
  • force_collinear (int) –
    Force all the welds along all layers to be collinear:
    0 - Non-collinear welds.
    1 - Collinear welds.
  • fe_type (int) – The FE type for the current solver specified in the FE. Configuration File for user-defined FE only.
Example#
Set the required properties for the connectors with ID 1, 2 and 3, and create a simple bar element with a tolerance of 1#
    import hm
    import hm.entities as ent
    model = hm.Model()
    connector_collection = hm.Collection(model, ent.Connector, [1, 2, 3])
    model.CE_FE_SetDetails(
        collection=connector_collection,
        config=60,
        property_id=1,
        system_flag=0,
        snap_to_node=0,
        remesh=0,
        force_collinear=0,
        fe_type=0,
