Model.blockwalleditrange#
- Model.blockwalleditrange(blockname, wallname, imin, imax, jmin, jmax, kmin, kmax, delete_cells)#
Adds or deletes a range of cells in a finite difference wall.
- Parameters:
blockname (hwString) – The name of the block.
wallname (hwString) – The name of the wall to be edited.
imin (double) – The minimum value in the i direction, inclusive.
imax (double) – The maximum value in the i direction, inclusive.
jmin (double) – The minimum value in the j direction, inclusive.
jmax (double) – The maximum value in the j direction, inclusive.
kmin (double) – The minimum value in the k direction, inclusive.
kmax (double) – The maximum value in the k direction, inclusive.
delete_cells (int) –
0 - Adds cells.
1 - Deletes cells.
Example#
Edit wall with name “wall1” on block with name “block1”#import hm model = hm.Model() model.blockwalleditrange( blockname="block1", wallname="wall1", imin=0.0, imax=0.0, jmin=0.0, jmax=0.0 kmin=0.0, kmax=0.0, delete_cells=0 )
