Model.movecuttingplane#
Model.movecuttingplane(axis, distance)#
Moves a cutting plane a specified distance.
Parameters:
  • axis (int) –
    The axis that is normal to the plane. Valid values are:
    0 - The plane with x-axis as its normal
    1 - The plane with y-axis as its normal
    2 - The plane with z-axis as its normal
  • distance (double) – The distance to move the cutting plane along the plane normal.
Example#
Move the cut plane with y - axis as its normal by a value of 5.0#
import hm
import hm.entities as ent
model = hm.Model()
model.movecuttingplane(axis=1, distance=5.0)
