Model.tabledeletecolumn#
Model.tabledeletecolumn(name, column_index)#
Deletes a column of data from a table.
Parameters:
  • name (hwString) – The name of the table to update.
  • column_index (unsigned int) – The index of the column to delete. Tables are indexed starting from 1 (1 to n columns). If specified as 0, the last column in the table is deleted.
Examples#
Delete the last column from “ table1 “ , which has 11 columns#
import hm
import hm.entities as ent
model = hm.Model()
model.tabledeletecolumn(name="table1", column_index=0)
Delete the last column from “ table1 “ , which has 11 columns ( Alternatively )#
import hm
model = hm.Model()
model.tabledeletecolumn(name="table1", column_index=11)
Delete column 3 from “ table1 “#
import hm
model = hm.Model()
model.tabledeletecolumn(name="table1", column_index=3)
