Model.CE_MarkSplitLink#
- Model.CE_MarkSplitLink(collection, search_type, search_rule, search_string_array, keep_realized=0)#
Splits group links into individual links.
- Parameters:
collection (Collection) – The collection containing the connector entities.
search_type (EntityFullType) – The specific link type to search in the connector. This must be specified. The supported entities are Component, Property, Surface, Tag, Element, Node and Part.
search_rule (unsigned int) –
The rule by which the link entity was added to the connector:
0 - Undefined
1 - None
2 - Use ID
3 - Use Name
4 - Proximity
5 - Use UID
search_string_array (hwStringList) – A string array containing the list of of link IDs/names/UIDs in the group link. The strings are generally IDs/names/UIDs based on the
search_rule.keep_realized (unsigned int) –
Option to keep the current connector state after the update operation:
0 - Unrealize if needed (default)
1 - Keep current state
Example#
Split the group link of 3 components consisting of component with IDs: 1, 2 and 4 in connector with ID 5#import hm import hm.entities as ent model = hm.Model() connectors = hm.Collection(model, ent.Connector, [5]) model.CE_MarkSplitLink( collection=connectors, search_type=ent.Component, search_rule=1, search_string_array=["3", "2", "4"], keep_realized=0, )
