Model.hm_wadlinesispointintestzone#
Model.hm_wadlinesispointintestzone(testpoint, tolerance, normal, num_pts, points)#
Returns whether a point is inside a test zone by taking in the coordinates of the zone boundary returned by Model.hm_wadlinesgetadulttestzone() and Model.hm_wadlinesgetchildtestzone(), along with the impact direction of the impact point. The impact point and zone boundary are projected to a plane perpendicular to the impact direction, then tested to find if the projection of the impact point is within the polygon defined by the zone boundary.
num_pts should always be provided before the points option.
Parameters:
  • testpoint (hwTriple) – The x/y/z coordinates of the impact point to be tested.
  • tolerance (double) – Test points that are within this tolerance to the zone boundary are also returned as inside the zone boundary. Default 1e-6.
  • normal (hwTriple) – The normal direction x/y/z of the plane to which the zone boundary and test point is projected. This is expected to be along the impact direction of the impact point.
  • num_pts (int) – The number of points defining the zone boundary. Must be provided before points.
  • points (hwDoubleList) – The ordered x/y/z coordinate values of all points of the zone boundary.
Returns:
Example#
Setup and extract WAD lines data#
import hm
import hm.entities as ent
model = hm.Model()
model.hm_wadlinesinit()
model.hm_wadlinesispointintestzone(
    testpoint=ent.Point(model, 38),
    tolerance=0,
    normal=[0, 0, 1],
    num_pts=10,
    points=[
        1343.514343661,
        709.91761797527,
        973.43251742578,
        1334.7036682323,
        703.07456401521,
        973.15886027621,
        1327.8482379749,
        697.4142871779,
        972.93366355648,
        1323.86674249,
        694.00118686161,
        972.79787178914,
        1310.125533079,
        681.68252694578,
        972.30776823337,
        1309.4710911285,
        681.07217688483,
        972.28348517521,
        1301.5068502671,
        673.437787072,
        971.97974746194,
        1297.3418689169,
        669.34475639184,
        971.81690435206,
        1293.2547572113,
        665.2922768409,
        971.65567458753,
        1289.222029365,
        661.21716017109,
        971.49354419],
model.hm_wadlinesend()
