Model.nodesassociatetogeometry#
- Model.nodesassociatetogeometry(collection, entity, tolerance)#
This function is used to associate nodes to points, lines, surfaces and solids. Association also moves/positions the nodes onto that geometric entity.
- Parameters:
collection (Collection) – The collection containing the node entities to position and associate.
entity (Entity) – The object describing the entity to use for assocation. Valid entities are points, lines, surfaces and solids. When surface entity is used, surface edges are also considered for the association.
tolerance (double) – The search tolerance to use for the association. Any nodes on
collectionthat are further than tolerance away from the specifiedentityare not associated.
Example#
Associatin the nodes with IDs 1-100 to surface with ID 5 using a tolerance of 0.01#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the nodes with IDs 1-100 filter_nodes = hm.FilterByEnumeration(ent.Node, list(range(1, 101))) nodes_collection = hm.Collection(model, filter_nodes) model.nodesassociatetogeometry( collection=nodes_collection, entity=ent.Surface(model, 5), tolerance=0.01 )
