Model.loadcreatewithsystemonentity#
Model.loadcreatewithsystemonentity(collection, config, type, comp1, comp2, comp3, comp4, comp5, comp6, system, transformflag)#
Creates a load (forces, temperature, moment, velocity, acceleration, or constraints) on nodes, fixed points (surface vertices or weld points), surface edges, and surfaces, defined in a local coordinate system.
Parameters:
  • collection (Collection) – The collection containing the entities. Valid entities are nodes, points, surface edges(lines) and surfaces.
  • config (int) –
    The config of the load to create. Valid options are:
    1 - Force
    2 - Moment
    3 - Constraint
    5 - Temperature
    6 - Nodal Flux
    8 - Velocity
    9 - Acceleration
  • type (int) – Solver dependent types of the referenced load config.
  • comp1 (double) – The component of the load being applied. For all configs except constraints (config=3), this component represents the load in x-direction.
  • comp2 (double) – The component of the load being applied. For all configs except constraints (config=3), this component represents the load in y-direction.
  • comp3 (double) – The component of the load being applied. For all configs except constraints (config=3), this component represents the load in z-direction.
  • comp4 (double) – The component of the load being applied. Applicable only for constraints (config=3).
  • comp5 (double) – The component of the load being applied. Applicable only for constraints (config=3).
  • comp6 (double) –
    Note
    For constraints, all of the components are active unless they are set equal to -999999.0. All of the other components of the constraints are active in the respective directions.
    For pressures, to create a pressure which is normal to the element, set all components to zero.
  • system (Entity) – The coordinate system to be used.
  • transformflag (int) –
    Indicates which system supplies component values. Valid options are:
    0 - If the component values are supplied in the global coordinate system.
    1 - If the component values are supplied in the local coordinate system.
Example#
Apply a temperature of 0 degrees with ID 4 to surface with ID 12#
surface_collection = hm.Collection(model, ent.Surface, [12])
model.loadcreatewithsystemonentity(
    collection=surface_collection,
    config=5,
    type=1,
    comp1=0.0,
    comp2=0.0,
    comp3=0.0,
    comp4=0.0,
    comp5=0.0,
    comp6=0.0,
    system=ent.System(model, 4),
    transformflag=1,
