Model.copytoclipboard#
Model.copytoclipboard(collectionset, componentrule='COMP_ONLY', holderrule='', includefileids=hwIntList(), includefilerule='IGNORE', referencerule='RESET')#
Copies entities to the HyperMesh clipboard.
Parameters:
  • collectionset (CollectionSet) – The set of collections containing possibly multiple type of entities to be copied.
  • componentrule (hwString) –
    The rule for components.
    COMP_ONLY - Copy the component only.
    FE - Copy the FE entities inside the component.
    GEOM - Copy the geometry entities inside the component.
    FE_AND_GEOM - Copy both the FE and geometry entities inside the component.
  • holderrule (hwString) –
    The rule for entities that contain other entities.
    ASSEMBLY - Also copy the assemblies and components that an assembly holds.
    CONFIGURATION - Also copy the parts, partsets and configurations that a configuration holds.
    PARTSET - Also copy the parts, partsets and partassemblies that a partset holds.
    PARTASSEMBLY - Also copy the parts and partassemblies that a partassembly holds.
    SUBSYSTEMCONFIGURATION - Also copy the subsystemconfigurations, subsystemsets and subsystems that a subsystemconfiguration holds.
    SUBSYSTEMSET - Also copy the subsystemsets and subsystems that a subsystemset holds.
    LOADCOL - Also copy the loads that a loadcolr holds.
    SYSTEMCOL - Also copy the systems that a systemcol holds.
    BEAMSECTCOL - Also copy the beamsects that a beamsectcol holds.
    VECTORCOL - Also copy the vectors that a vectorcol holds.
    LAMINATE - Also copy the plies that a laminate holds.
    ALL - Enforce all the above.
  • includefileids (hwIntList) – The ID or the list of IDs of include files to be explicitly copied together with their related entities. If this argument is present, includefilerule is ignored.
  • includefilerule (hwString) –
    The rule for include files.
    IGNORE - Ignore include files and do not copy them.
    COPY - Copy include files together with the hierarchy.
  • referencerule (hwString) –
    The rule for references.
    RESET - Reset all references.
    COPY_UNDEFINED - Copy references as undefined.
    COPY_UNRESOLVED - Copy references as unresolved.
    COPY_BOTH - Copy references both as undefined and unresolved.
Example#
Copy all entities in the collectionset to clipboard with component option only FE, copy references, ignore include files and enforce all the holderrule options#
import hm
import hm.entities as ent
model = hm.Model()
elements_collection = hm.CollectionByInteractiveSelection(model, ent.Element)
CollectionSet = hm.CollectionSet(model)
CollectionSet.set(elements_collection)
model.copytoclipboard(
    collectionset=CollectionSet,
    componentrule="FE",
    referencerule="COPY",
    includefilerule="IGNORE",
    holderrule="ALL",
