Model.elempatchstartaction#
Model.elempatchstartaction(patch_type, threshold)#
Starts the QI patch checker.
This function only functions between a Model.elementqualitysetup() function and a Model.elementqualityshutdown() function.
Parameters:
  • patch_type (int) – Must be set to 0.
  • threshold (double) –
    Threshold value for the element quality:
    0.8 - Warning elements
    1.0 - Failed elements
    10.0 - Worst elements
Example#
Start the patch checker and move through several patches , change the patch size , while use quality criteria given from a file#
import hm
import hm.entities as ent
model = hm.Model()
model.readqualitycriteria(file_name="c:/criteria/mycriteria.txt")
elementcollection = model.CreateCollectionByDisplayed(ent.Element)
model.elementqualitysetup(elementcollection=elementcollection)
model.elempatchstartaction(patch_type=0, threshold=1.0)
model.elempatchnextaction()
model.elempatchincraction()
model.elempatchprevaction()
model.elempatchdecraction()
model.elempatchstopaction()
model.elementqualityshutdown(dontsaveflag=1)
