Model.solid_prepare_nodeline#
- Model.solid_prepare_nodeline(start)#
Setups an internal node array that is used by the solid mapping algorithm. It must be used within a
Model.solidmap_prepare_usrdataptr()data input block. A data input block begins withModel.solidmap_prepare_usrdataptr()and ends with either a call toModel.solidmap_end()or the start of another data input sub-block.- Parameters:
start (int) – A flag that indicates how to handle the nodes on the previous node collection. A value of 0 indicates to start a new internal node array. Otherwise, the list is appended to the previous internal node array.
Example#
For a solidmap using the following inputs: Source geometry - lines with IDs 73 and 51; Destination geometry - lines with IDs 32 and 41; Along geometry - lines with IDs 74 and 75, surfaces with IDs 100 and 95, nodes with IDs 80 and 101-105; Element size - 10.0#import hm import hm.entities as ent model = hm.Model() model.solidmap_begin(ordered=1) model.solidmap_prepare_usrdataptr(type="SOURCE", options=10) source_line_collection = hm.Collection(model, ent.Line, [73, 51]) model.solid_prepare_entitylst(entity_type=ent.Line, reserved=0) model.solidmap_prepare_usrdataptr(type="DEST", options=2) dest_line_collection = hm.Collection(model, ent.Line, [32, 41]) model.solid_prepare_entitylst(entity_type=ent.Line, reserved=0) model.solidmap_prepare_usrdataptr(type="ALONG", options=7) along_line_collection = hm.Collection(model, ent.Line, [74, 75]) model.solid_prepare_entitylst(entity_type=ent.Line, reserved=0) surfaces_collection = hm.Collection(model, ent.Surface, [100, 95]) model.solid_prepare_entitylst(entity_type=ent.Surface, reserved=0) node_list = [ ent.Node(model, 80), ent.Node(model, 101), ent.Node(model, 102), ent.Node(model, 103), ent.Node(model, 104), ent.Node(model, 105), ] model.solid_prepare_nodeline(start=0) model.solidmap_end(options=0, density_or_size=10.0, bias_style=0, biasing=0, elemDest=0)
