Model.displaycollectorsall#
Model.displaycollectorsall(mode, elements, geometry)#
Controls the display state of all collectors.
Parameters:
  • mode (hwString) –
    The mode being performed, defined by the following:
    on - All collectors are turned on.
    all - All collectors are turned on.
    off - All collectors are turned off.
    none - All collectors are turned off.
    toggle - All collectors are toggled (visible become invisible and vice-versa).
    reverse - All collectors are toggled (visible become invisible and vice-versa).
  • elements (int) –
    Indicates if elements within collectors are to be turned on or off.
    0 - No
    1 - Yes
  • geometry (int) –
    Indicates if geometry within collectors are to be turned on or off.
    0 - No
    1 - Yes
Example#
Turn off all entities in the user collection , except geometry#
import hm
import hm.entities as ent
model = hm.Model()
model.displaycollectorsall(mode="off", elements=1, geometry=0)
