Model.CE_ConnectorAreaTrim#
- Model.CE_ConnectorAreaTrim(collection, node_collection, tolerance, snap, mode)#
Trim/split area connectors using nodes.
- Parameters:
collection (Collection) – The collection containing the area connector entities to trim.
node_collection (EntityList) – The list containing the node entities to trim or split.
tolerance (double) – The tolerance value used to snap the nodes to the points of area connectors when
snap=1.snap (int) –
0 - Do not snap nodes to area connectors.
1 - Snap nodes to area connectors.
mode (int) –
0 - Split area connectors.
1 - Trim area connectors.
Example#
Split area connector with ID 101 using node with ID 1001#import hm import hm.entities as ent model = hm.Model() connector_collection = hm.Collection(model, ent.Connector, [101]) model.CE_ConnectorAreaTrim( collection=connector_collection, node_collection=[ent.Node(model, 1001)], tolerance=0.5, snap=1, mode=0, )
