Model.setsimulationstep#
- Model.setsimulationstep(subcase_id, simulation_id)#
Sets the current subcase and simulation step. All the result plots retrieve their values based on the current subcase and simulation step.
- Parameters:
subcase_id (int) – The HyperMesh result subcase ID.
simulation_id (int) – The HyperMesh result simulation ID. The referenced result simulation should belong to the referenced result subcase.
Example#
Set the simulation step with ID 1 of subcase with ID 2 as current#import hm import hm.entities as ent model = hm.Model() model.setsimulationstep(simulation_id=2, simulation_id=1)
