Model.hm_ce_mesh_imprint_option_set#
- Model.hm_ce_mesh_imprint_option_set(name, value)#
Sets a mesh imprint option value.
- Parameters:
name (hwString) –
Valid names are:
avoid_imprint - If enabled, create patches and resolve conflicts, skip mesh imprint.
avoid_int_snapping - If enabled, avoid snapping in meshing side.
keep_snap - If enabled, do snapping during patch creation.
skip_imprint - If enabled, just create patches, skip mesh imprint.
skip_overlap_check - If enabled, skip conflict checks.
strict_imprint - If enabled, any conflict causes an error.
value (unsigned int) – The value of the option, 0 or 1.
- Returns:
hwReturnStatus- Status object
Example#
Set the value of avoid_imprint to 1#import hm import hm.entities as ent model = hm.Model() model.hm_ce_mesh_imprint_option_set( name="avoid_imprint", value=1 )
