Model.barelementcreatewithoffsets#
- Model.barelementcreatewithoffsets(node1, node2, vector, orientation_node, y_dir, pin_flags_a, pin_flags_b, property_name, offset_system_a, offset_x_a, offset, y_a, offset_z_a, offset_system_b, offset_x_b, offset_y_b)#
Creates a bar element with offsets.
- Parameters:
node1 (Entity) – The first node ID (end a).
node2 (Entity) – The second node ID (end b).
vector (hwTriple) – The hwTriple object defining the vector components. User can also supply a Python list of three doubles.
orientation_node (Entity) – The orientation node ID. If set to None, then
vectoris used. If non-zero, theny_dirspecifies whether this node defines the local y- or local z-axis.y_dir (int) – If set to 1, then
orientation_nodedefines the local y-axis of the bar. Otherwise, orientation_node defines the local z-axis.pin_flags_a (hwBoolList) – The pin flags at end a. A pin flag of None passes forces in all degrees of freedom.
pin_flags_b (hwBoolList) – The pin flags at end b. A pin flag of None passes force in all degrees of freedom.
property_name (hwString) – The name of the property collector assigned to the bar.
offset_system_a (int) –
The system used to define the offsets at end a. Valid values are:
0 - Offsets given in global coordinate system.
1 - Offsets given in local coordinate system of node1.
2 - Offsets given in elemental coordinate system.
offset_x_a (double) – The offset in the x-direction at end a.
offset_y_a (double) – The offset in the y-direction at end a.
offset_z_a (double) – The offset in the z-direction at end a.
offset_system_b (int) –
The system used to define the offsets at end b. Valid values are:
offset_x_b (double) – The offset in the x-direction at end b.
offset_y_b (double) – The offset in the y-direction at end b.
offset_z_b (double) – The offset in the z-direction at end b.
Example#
Create a bar3 element between nodes with IDs 101, 102 and 103 with its local y-axis defined by the vector (1, 0, and 0) and assigned property “prop1”. The element has an offset vector at end a defined using the global system (0.2, 0.2, and 0.2) and offset vector at end b defined using the global system (0.3, 0.3, and 0.3)#import hm import hm.entities as ent model = hm.Model() model.barelementcreatewithoffsets( node1=ent.Node(model, 101), node2=ent.Node(model, 102), vector=(1, 0, 0), orientation_node=None, y_dir=0, pin_flags_a=None, pin_flags_b=None, property_name="prop1", offset_system_a=0, offset_x_a=0.2, offset_y_a=0.2, offset_z_a=0.2, offset_system_b=0, offset_x_b=0.3, offset_y_b=0.3, offset_z_b=0.3 )
