Model.elementtestaspect#
- Model.elementtestaspect(collection, aspect, output_collection, dimension, contour, title)#
Tests 2D and 3D elements using the aspect element quality check.
- Parameters:
collection (Collection) – The collection containing the element entities to test.
aspect (double) – The value to use as a threshold beyond which elements should be considered to have failed the test.
output_collection (Collection) – The collection containing the failed element entities.
dimension (int) –
The option of whether to measure 2D or 3D elements:
2 - Measure 2D elements.
4 - Measure 3D elements.
contour (int) –
Flag that determines how the results are presented. Valid values are:
0 - Display the results of the test normally.
1 - Display the elements color coded by their ratings.
2 - Build a histogram showing the distribution of ratings.
title (hwString) – The title to label the curve in the histogram. Only required, if contour is 2.
Examples#
Testing all displayed 3D elements for an aspect of 5.0#import hm import hm.entities as ent model = hm.Model() elems1 = model.CreateCollectionByDisplayed(ent.Element) elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([]))) model.elementtestaspect( collection=elems1, aspect=5.0, output_collection=elems2, dimension=4, contour=0, title="" )
Testing all displayed 2D elements for an aspect of 6.0#import hm import hm.entities as ent model = hm.Model() elems1 = model.CreateCollectionByDisplayed(ent.Element) elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([]))) model.elementtestaspect( collection=elems1, aspect=6.0, output_collection=elems2, dimension=2, contour=0, title="" )
