Model.hm_comparewritefile#
Model.hm_comparewritefile(filename)#
Writes the current comparison data (transformations, match types, match entities, etc.) to a file. This must be preceded by a call to a relevant hm_compareentities function.
This file can be reloaded using Model.hm_comparereadfile() to repopulate the results in a different session.
Parameters:
filename (hwString) – The full name and path of the file to write the data to.
Returns:
Example#
Write the comparison data file to “ C:/temp / my_compare.txt “ for the same side comparison of surfaces with IDs 1 - 20 and 101 - 120#
import hm
import hm.entities as ent
model = hm.Model()
surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21)))
surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121)))
model.hm_compareinit()
model.hm_compareentitiessameside(
    source_entities=surfs1,
    target_entities=surfs2,
    tolerance=0.1,
    result_type=2,
    review_results=False,
model.hm_comparewritefile( filename="C:/temp/my_compare.txt")
model.hm_compareend()
