Model.fixnarrowsurfaces#
- Model.fixnarrowsurfaces(collection, width_threshold, mesh_type, fix_flag, string_options)#
Fixes narrow surfaces and surfaces having local narrow regions like tails and necks.
It is intended to eliminate sliver elements while meshing and sometimes to allow meshing surfaces otherwise non-meshable. Different levels of fixes can be provided for different types of meshing.
- Parameters:
collection (Collection) – The collection containing the input entities.
width_threshold (double) – The width threshold for considering surfaces as narrow. It should be a positive value much smaller than the target element size for meshing of the model.
mesh_type (int) –
The targeted mesh type:
0 - Meshing using surface topology. Sliver surfaces, narrow surface tails and necks are identified and corresponding edges and points are self-stitched together. Collapsed surfaces are removed.
1 - Meshing the splines (faces) topology. Sliver surfaces, narrow surface tails and necks are identified and corresponding edges are points are self-stitched together. Collapsed surfaces are removed. Gaps between surfaces and vertices exceeding the geometry_fix_tol are eliminated.
fix_flag (int) – When set to 1, performs geometry topology matching to morph the geometry to close physical gaps caused by stitching.
string_options (hwString) –
An optional input string containing additional input parameters. The data for each input parameter consists of the predefined parameter keyword and the parameter value separated by space characters and /or equality symbol: parameter_keyword = parameter_value or parameter_keyword parameter_value.
Supported parameters are:
geometry_fix_tol = tolerance
The maximum gap allowed between edges and vertices, when eliminating geometry gaps for
mesh_type. If not specified, the value is auto defined.max_sharp_angle = angle
The corner angle above which the area nearby a surface corner is not considered a local narrow region. Default is 10 degrees.
Examples#
Find and fix narrow surfaces with a width less than 0.4. Do not eliminate geometry gaps#import hm import hm.entities as ent model = hm.Model() surfs = hm.CollectionByDisplayed(model, ent.Surface) model.fixnarrowsurfaces( collection=surfs, width_threshold=0.4, mesh_type=0, fix_flag=0, string_options="" )
Find and fix narrow surfaces with a width less than 0.4. Eliminate geometry gaps, using an auto-defined tolerance#import hm import hm.entities as ent model = hm.Model() surfs = hm.CollectionByDisplayed(model, ent.Surface) model.fixnarrowsurfaces( collection=surfs, width_threshold=0.4, mesh_type=1, fix_flag=0, string_options="" )
Find and fix narrow surfaces with a width less than 0.4. Eliminate geometry gaps more than 0.02#import hm import hm.entities as ent model = hm.Model() surfs = hm.CollectionByDisplayed(model, ent.Surface) model.fixnarrowsurfaces( collection=surfs, width_threshold=0.4, mesh_type=1, fix_flag=0, string_options="geometry_fix_tol = 0.02" )
