Model.accepteditedsurface_with_user_tolerance#
Model.accepteditedsurface_with_user_tolerance(auto_stitch, tolerance)#
Moves surfaces from the midsurface to edit component into the middle surface component and stitches surfaces according to a specified tolerance.
Parameters:
  • auto_stitch (int) –
    An option that permits auto-stiching operation of surfaces. Valid values are:
    \(=\) 0 - Auto-stitch is disabled.
    \(\ne\) 0 - Auto-stitch combines surfaces using the specified tolerance.
  • tolerance (double) –
    Surfaces within this decimal-value tolerance are stitched together if auto_stitch is enabled.
    If auto_stitch is enabled but tolerance is less than zero, then the result is stitched with a tolerance of 1/5 the midsurface thickness.
Example#
Move midsurfaces from midsurface to edit into middle surface with a stitch tolerance equal to ¼ of the midsurface thickness#
import hm
import hm.entities as ent
model = hm.Model()
model.accepteditedsurface_with_user_tolerance(auto_stitch=1, tolerance=0.25)
