Model.hm_comparesetreview#
- Model.hm_comparesetreview(type, min_legend=0, max_legend=0)#
Sets the graphical review type for comparison results. This must be preceded by a call to a relevant hm_compareentities function. For distance review, a call must also be made to hm_comparefinddistances. This is cleared upon a call to
Model.hm_compareend().- Parameters:
type (int) –
0 - Off
1 - Comparisons
2 - Distance
min_legend (double) – Value that indicates the minimum value to use for the legend when
type=2. If not specified, the default is 0.0.max_legend (double) – Value that indicates the maximum value to use for the legend when
type=2. If not specified, the default is the maximum distance.
- Returns:
hwReturnStatus- Status object
Example#
Generate a same side comparison of surfs with IDs 1 - 20 and elems with IDs 101 - 120 , use the 2D shell thickness and offset , ignore fillets and all holes < 8.0 in diameter#import hm import hm.entities as ent model = hm.Model() elems1 = hm.Collection(model, ent.Element, list(range(1, 21))) elems2 = hm.Collection(model, ent.Element, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiessameside( source_entities=elems1, target_entities=elems2, tolerance=0.1, result_type=2, review_results=False, ) model.hm_comparefinddistances(max_distance=1.0, review_results=True) model.hm_comparesetreview(type=2) model.hm_compareend()
