Model.markintersectplane#
- Model.markintersectplane(entitycollection, plane_normal, plane_base, elemoutcollection, nodeoutcollection)#
Selects a chain of elements and nodes cut by a given section plane.
- Parameters:
entitycollection (Collection) – The collection containing the entities to be intersected. Valid entities are elements and components.
plane_normal (hwTriple) – The hwTriple object defining the components of the normal of the section plane. User can also supply a Python list of three doubles.
plane_base (hwTriple) – The hwTriple object defining the base point components of the section plane. User can also supply a Python list of three doubles.
elemoutcollection (Collection) – The collection containing the entities of the intersected elements.
nodeoutcollection (Collection) – The collection containing the entities of one row of nodes along the intersected elements.
Example#
Find the nodes and elements inside of the components collection cut by a user - defined plane , and place these nodes / elems into collections#import hm import hm.entities as ent model = hm.Model() Entity_Collection = hm.CollectionByDisplayed(model, ent.Component) ElemOutCollection = hm.Collection(model, ent.Element, populate=False) NodeOutCollection = hm.Collection(model, ent.Node, populate=False) model.markintersectplane( entitycollection=Entity_Collection, plane_normal=[0.0002 -0.3832 0.0004], plane_base=[850.3620 237.5095 349.0000], elemoutcollection=ElemOutCollection, nodeoutcollection=NodeOutCollection, )
