Model.createbestcirclecenternode#
- Model.createbestcirclecenternode(collection, point_flag, any_tol, make_circle)#
Creates a node or a point at the center of the circle that best approximates the input set of lines or points. If the input entities are found to be on a straight line, then an error is returned.
- Parameters:
collection (Collection) – The collection containing the input entities. Valid entities are nodes, points and lines.
point_flag (int) –
Parameter specifying whether a node or point is created at the approximated circle center. Valid values are:
0 - Create node.
1 - Create point.
any_tol (int) –
Parameter specifying whether the best fit is verified against the currently set geometry cleanup tolerance. Valid values are:
0 - An error is returned, if the input entities are not on the circle within the geometry cleanup tolerance.
1 - Tolerance is ignored and best fit circle is always calculated.
make_circle (int) –
Parameter specifying whether a circle is also created:
0 - Only center point/node is created.
1 - Center point/node and a circle are created.
Examples#
Create a node at the center of the circle passing through nodes with IDs 11, 12 and 14#import hm import hm.entities as ent model = hm.Model() model.createbestcirclecenternode( collection=hm.Collection(model, ent.Node, [11, 12, 13]), point_flag=0, any_tol=1, make_circle=0, )
Create a circle that approximates line with ID 21, along with a point at the center of the circle#import hm import hm.entities as ent model = hm.Model() model.createbestcirclecenternode( collection=hm.Collection(model, ent.Node, [21]), point_flag=1, any_tol=1, make_circle=1, )
