Model.hm_entitylist#
- Model.hm_entitylist(entity, listType, mode='active')#
Returns a list of names or IDs of all entities of the requested type.
- Parameters:
entity (EntityFullType) – The type of entity to query.
listType (hwString) –
The type of list to generate. Valid values are:
name - Return the list of names. Only named entity types support this option.
id - Return the list of IDs. All entity types support this option.
solvername - Returns the list of solver names for entity types enabled for name pool.
mode (hwString) –
An optional argument that specifies which entity types are returned:
active - Return only the active entities. This is the default if not specified.
all - Return both active and inactive entities.
inactive - Return only the inactive entities.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:Keys valid for
listType="name"entityList (list of strings)
Keys valid for
listType="id"entityList (numpy.ndarray)
Keys valid for
listType="solvername"entityList (list of strings)
Examples#
Get the list of node IDs#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_entitylist(entity=ent.Node, listType="id") print(result.entityList)
Get the list of of component names#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_entitylist(entity=ent.Component, listType="name") print(result.entityList)
