Model.CE_InputSigPoints#
- Model.CE_InputSigPoints(tolerance, entity_collection, connector_collection)#
Imprints nodes or points as significant points on connectors.
- Parameters:
tolerance (double) – The tolerance value defining the maximum distance between the nodes/points and the selected connectors.
entity_collection (Collection) – The collection containing the node or point entities to be imprinted.
connector_collection (Collection) – The collection containing the connector entities on which to add the significant points.
Example#
Imprint points with IDs 1-10 as significant points on connector with ID 1 using a tolerance 100.0#import hm import hm.entities as ent model = hm.Model() model.CE_InputSigPoints( tolerance=100.0, entity_collection=hm.Collection(model, ent.Point, list(range(1, 11))), connector_collection=hm.Collection(model, ent.Connector, [1]) )
