Model.hm_comparereadfile#
- Model.hm_comparereadfile(filename, overwrite)#
Reads comparison data (transformations, match types, match entities, etc…) from a file into the comparison database. This must be preceded by a call to
Model.hm_compareinit().This is useful for large comparisons that take a lot of time to generate. The data can be saved to a file and reloaded in a new session to save time.
- Parameters:
filename (hwString) – The full name and path of the file to read the data from.
overwrite (bool) –
0 - Do not overwrite existing comparison results
1 - Overwrite existing comparison results
- Returns:
hwReturnStatus- Status object
Examples#
Write the detailed comparison results file to “ C:/temp / my_compare.txt “ for the same side comparison of surfaces with IDs 1 - 20 and 101 - 120#import hm import hm.entities as ent model = hm.Model() surfs1 = hm.Collection(model, ent.Surface, list(range(1, 21))) surfs2 = hm.Collection(model, ent.Surface, list(range(101, 121))) model.hm_compareinit() model.hm_compareentitiessameside( source_entities=surfs1, target_entities=surfs2, tolerance=0.1, result_type=2, review_results=False, ) model.hm_comparewriteresults( filename="C:/temp/my_compare.txt", source_component_id=0, target_component_id=0 ) model.hm_compareend()
Read the comparison data file from C:/temp / my_compare.txt and review the distances#import hm import hm.entities as ent model = hm.Model() model.hm_compareinit() model.hm_comparereadfile(filename="C:/temp/my_compare.txt", overwrite=1) model.hm_comparefinddistances(max_distance=1.0, review_results=True) model.hm_comparesetreview(type=2) model.hm_compareend()
