Model.penetrationcheck#
- Model.penetrationcheck(collection, check_type)#
Checks the given components for contact surface penetrations. To release the memory after completion, use the function
Model.penetrationcheckend(). A valid template must be loaded for the check to occur.- Parameters:
collection (Collection) – The collection containing the entities to check for penetration. Valid entities are groups and elements
check_type (int) –
The type of penetration check to perform. Valid values are:
0 - groups
3 - elements only
Example#
Check the elements in group “ E2E “ for penetration#import hm import hm.entities as ent model = hm.Model() # Creating the collection that contains the elements from the group named "E2E" filter = hm.FilterByCollection(ent.Element, ent.Group) groups_collection = hm.Collection(model, ent.Group, "name=E2E") elements_collection = hm.Collection(model, filter, groups_collection) model.penetrationcheck(collection=elements_collection, check_type=0) model.penetrationcheckend()
