Model.lines_approximate#
- Model.lines_approximate(collection, type, reserved1, reserved2)#
Simplifies curved free lines.
- Parameters:
collection (Collection) – The collection containing the free line entities.
type (int) –
1 - Each curved line will be replaced with a parabola (2nd degree) that has the same end points as the line, and is closest to it.
2 - Each curved line will be simplified by removal of all internal knots but one (known as Bezier simplification).
reserved1 (int) – Reserved for future use. Must be set to 0.
reserved2 (double) – Reserved for future use. Must be set to 0.
Example#
Simplify the lines with IDs 1 and 2 by using Bezier simplification#import hm import hm.entities as ent model = hm.Model() model.lines_approximate( collection=hm.Collection(model, ent.Line, [1, 2]), type=2, reserved1=0, reserved2=0 )
