Model.setcomptopologydisplay#
- Model.setcomptopologydisplay(compid, disp_type)#
Sets the various types of geometry display at the component level.
- Parameters:
compid (int) – The ID of the component for which you wish to set the topology display mode.
disp_type (int) –
The type of topology display:
0 - Wireframe only
1 - Shaded with edges
2 - Shaded without edges
3 - Wireframe with internal surface lines
Example#
Set the component with ID 1 to the wire frame display mode#import hm import hm.entities as ent model = hm.Model() model.setcomptopologydisplay(compid=1, disp_type=0)
