Model.hm_getmatching#
Model.hm_getmatching(collection, areaCalcMethod='ByLowestId', compareType=0, deformationTolerance=0.000000, encodingAlgorithm=0, matchingPercentThreshold=0.000000, referenceCollection=Collection(), searchMethod='ByArea', sphharBandwidth=16.000000, sphharFallof=2.828427, sphharRadii=32.000000, sphharResolution=64.000000)#
Performs a comparison and returns matching results.
Returns a matching pair of components or parts passed along with the percentage match. The reference/target entities are sequenced first in the output, followed by matching source entities, and subsequently followed by the matching percentage. If a source entity matches with more than one target, the pairs with maximum match percentage are returned. A source returned with one reference is not part of any other match pair.
Parameters:
  • collection (Collection) – The collection containing the entities to compare. Valid entities are components or parts.
  • areaCalcMethod (hwString) –
    Specifies how the matching area percentage is calculated:
    ByLowestId - Calculate with respect to the entity with the lowest ID (default).
    ByHighestArea - Calculate with respect to the entity with the highest area.
    ByLowestArea - Calculate with respect to the entity with the lowest area.
    This is ignored when searchMethod="ByEncoding".
  • compareType (int) –
    Specifies with what entities the comparison happens:
    0 - Use both CAD and FE from the input selection.
    1 - Prefer CAD over FE. This will pick FE only if the input has only FE.
    2 - Use only CAD.
    3 - Prefer FE over CAD. This will pick CAD only if the input has only CAD.
    4 - Use only FE.
  • deformationTolerance (double) – The matching area threshold above which matching pairs are returned (default is node tolerance).
  • encodingAlgorithm (int) –
    The optional encoding algorithm to use when searchMethod="ByEncoding". Valid values are:
    0 - Spherical harmonics (default).
  • matchingPercentThreshold (double) – The matching area threshold above which matching pairs are returned (default is node tolerance).
  • referenceCollection (Collection) – The collection containing the reference/target entities. Valid entities are components or parts.
  • searchMethod (hwString) –
    Specifies how the matching is done:
    ByArea - Matching is done with repect to area (default).
    ByEncoding - Matching is done with respect to encoding.
    ByTopo - Matching is done with repect to exact topo matches.
  • sphharBandwidth (double) – Optional, valid for encoding_algorithm=0, default 16.
  • sphharFallof (double) – Optional, valid for encoding_algorithm=0, default 2.828427.
  • sphharRadii (double) – Optional, valid for encoding_algorithm=0, default 32.
  • sphharResolution (double) – Optional, valid for encoding_algorithm=0, default 64.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResultList - Result list object containing HmQueryResult objects with the following output data:
    • referenceEntity (Entity) - The reference entity (first in the pair) - Entity Type: Component or Part
    • matchedEntities (EntityList) - The list of matched entities (second in the pair).
    • matchPercentage (double) - The percentage match between the reference and matched entities.
Examples#
Compare part with ID 4 to part with ID 6 use a tolerance of 1.0#
import hm
import hm.entities as ent
model = hm.Model()
parts1 = hm.Collection(model, ent.Part, "id=4")
parts2 = hm.Collection(model, ent.Part, "id=6")
_, resultlist = model.hm_getmatching(
    collection=parts1,
    deformationTolerance=1.0,
    referenceCollection=parts2
for result in resultlist:
    print("referenceEntity: ", result.referenceEntity)
    print("matchedEntities: ", result.matchedEntities)
    print("matchPercentage: ", result.matchPercentage)
Compare part with ID 4 to part with ID 6 use the encoding search with a tolerance of 0.6 and use both CAD and FE#
import hm
model = hm.Model()
    collection=parts1,
    compareType=0,
    referenceCollection=parts2,
