Model.surfacespherefromthreepoints#
- Model.surfacespherefromthreepoints(center_node, radius, r_node, theta_start, theta_end, angle_node, phi_start, phi_end, angle_type)#
Creates a full or partial sphere, and optionally, prepares it for immediate use within the automesher. It can also identify a region in the shape of such a sphere for the automesher to use under the mesh without surface option.
- Parameters:
center_node (Entity) – A node specifying the center.
radius (double) – The radius of the sphere.
r_node (Entity) – A node specifying the r vector.
theta_start (double) – Angle at which theta starts (0.0 to < theta end).
theta_end (double) – Angle at which theta ends (> theta start to 360.0).
angle_node (Entity) – A node specifying the angle vector.
phi_start (double) – Angle at which phi starts (-90.0 to < phi end).
phi_end (double) – Angle at which phi ends (> phi start to 90.0).
angle_type (int) –
Defines whether the angle vector is to be theta or phi.
0 - The angle vector will be theta.
1 - The angle vector will be phi.
Example#
Create one quarter of a sphere with a radius of 10.0 through use nodes with IDs 1 , 2 and 3 , but not create any elements#import hm import hm.entities as ent model = hm.Model() model.surfacemode(mode=4) model.surfacespherefromthreepoints( center_node=ent.Node(mode, 1), radius=10.0, r_node=ent.Node(model, 2), theta_start=0.0, theta_end=180.0, angle_node=ent.Node(model, 3), phi_start=0.0, phi_end=90.0, angle_type=0, )
Note
The model.surfacemode(mode=4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
