Model.modelcheck_applyautocorrectiononmark#
- Model.modelcheck_applyautocorrectiononmark(checkDisplayName, collectionset, correctionDisplayName)#
Runs auto correction on specific entities for a given check, if checks are run.
- Parameters:
checkDisplayName (hwString) – The GUI display name of the check. This is case sensitive.
collectionset (CollectionSet) – The set of collections containing possibly multiple type of entities for which the model checker is to be run.
correctionDisplayName (hwString) –
The GUI name of the correction. This is case sensitive.
If not provided, the then default auto correction associated with the check is applied.
Example#
Run the “Delete unused materials” auto correction for all “Unused materials”#import hm import hm.entities as ent model = hm.Model() mat_collection = hm.Collection(model, ent.Material) collection_set = hm.CollectionSet(model) collection_set.set(mat_collection) model.modelcheck_applyautocorrectiononmark( checkDisplayName="Unused materials", collectionset=collection_set, correctionDisplayName="Delete unused materials", )
