Model.segmentsetcreatewithshells#
- Model.segmentsetcreatewithshells(name, color, collection, reverse_normals)#
Creates a segment set using 1D or 2D elements.
- Parameters:
name (hwString) – The name of the segment set to update.
color (int) – The color of the segment set. Valid values are 1-64.
collection (Collection) – The collection containing the entities to add.
reverse_normals (int) –
Create segment set:
0 - Along element normal
1 - Opposite element normal
Example#
Create a segment set named “ test “ with the elements with IDs 1 - 100#import hm import hm.entities as ent model = hm.Model() # Creating a collection that contains the elements to add filter_elements = hm.FilterByEnumeration(ent.Element, list(range(1, 101))) elements_collection = hm.Collection(model, filter_elements) model.segmentsetcreatewithshells( name="test", color=5, collection=elements_collection, reverse_normals=0 )
