Model.CE_ConvertLinksByMark#
Model.CE_ConvertLinksByMark(collection, target_entity_type, link_index, target_link_rule=0, target_link_state=0, keep_current_state=0)#
Converts connector links to a new entity type.
Parameters:
  • collection (Collection) – The collection containing the connector entities to update.
  • target_entity_type (EntityFullType) – The entity type to which the link is converted. Valid values are components, properties and parts.
  • link_index (int) –
    The index of the link to be converted, starting from 0.
    -1 - all links are converted
  • target_link_rule (int) –
    The optional rule to set for the converted link entity. Valid rules are:
    0 - Undefined
    1 - None
    2 - Use ID
    3 - Use name
    4 - Proximity
    5 - Use UID
  • target_link_state (int) –
    The flag to set for the link entity that specifies if you are connecting to mesh or to geometry. The supported values are:
    0 - Undefined
    1 - Connect to mesh
    2 - Connect to geometry
  • keep_current_state (unsigned int) –
    Optional option to keep the current connector state after the update operation. Valid states are:
    0 - Unrealize if needed (default)
    1 - Keep current state
Examples#
Convert all displayed connectors at link index 0 to part links#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_ConvertLinksByMark(
    collection=hm.CollectionByDisplayed(model, ent.Connector),
    target_entity_type=ent.Part,
    link_index=0,
Convert all links of connector with ID 3 to part links#
import hm
model = hm.Model()
    collection=hm.Collection(model, ent.Connector,[3]),
    link_index=-1,
Convert all links of displayed connectors to part links using the UID rule#
import hm
model = hm.Model()
    link_index=-1,
    target_link_rule=5,
