Model.hm_fbdplot#
Model.hm_fbdplot(plot_type, collection, subcase_ids, resultid, absolute=0, arrlen=25, arroworigin=0, colorfx=255, colorfy=65280, colorfz=16711680, colorfxy=0, colorfyz=0, colorfxz=0, colorfxyz=0, colormx=255, colormy=65280, colormz=16711680, colormxy=0, colormyz=0, colormxz=0, colormxyz=0, createfield=1, createload=1, display=1, displacement=0, declim=2, envelope=0, freenode=0, fx=255, fxy=0, fxyz=0, fxz=0, fy=65280, fyz=0, fz=16711680, gpf=0, midarrow=0, minmax=0, mx=255, mxy=0, mxyz=0, mxz=0, my=65280, myz=0, mz=16711680, normalload=0, onelems=0, onnodes=0, plotdir=0, resfileid=1, resolvein_sys=0, rotation=0, scid=1, scientific=0, showvalue=0, stepid=0, sizescale=0, tangentialLoad=0, tolerance=1e-05, user_sys_id=Entity(), vecstyle=0, intf=0, mpcf=0, sumat=0, sysproj=0, spcf=0, appf=0, color=255, createtable=0, displayat=0, field_name='', interpolate=0, maxval=0.000000, range=1, report_tablename='', resultant=0, summf=0)#
Creates FBD panel or bar plots. The plots can be cleared using Model.hm_fbdplot_clear().
Parameters:
  • plot_type (hwString) –
    The type of plot to generate:
    barplot - Create FBD bar plot
    panelplot - Create FBD panel plot
  • collection (Collection) – The collection containing the input panels or freebodysections.
  • subcase_ids (hwTripleIList) – The subcase IDs to consider, as a list with integer triples. Each triple consisting of the result file ID, subcase ID and step ID. Example: subcase_ids=[[1 1 0], [1 2 0], [2 1 0], [2 1 1]].
  • resultid (Entity) – The result entity to use. This is a mandatory option.
  • absolute (int) –
    0 - Algebraic envelope plot (default)
    1 - Absolute envelope plot
  • arrlen (double) – The plot arrow length in percentage (default 75).
  • arroworigin (int) –
    For bar plots only:
    0 - Tail of arrow at node (default)
    1 - Tip of arrow at node
  • colorfx (unsigned int) – The bar plot Fx force and panel plot normal load arrow color. Valid values are 1-64.
  • colorfy (unsigned int) – The bar plot Fy force and panel plot tangential load arrow color. Valid values are 1-64.
  • colorfz (unsigned int) – The bar plot Fz force arrow color. Valid values are 1-64.
  • colorfxy (unsigned int) – The color of the Fxy arrow. Valid values are 1-64.
  • colorfyz (unsigned int) – The color of the Fyz arrow. Valid values are 1-64.
  • colorfxz (unsigned int) – The color of the Fxz arrow. Valid values are 1-64.
  • colorfxyz (unsigned int) – The color of the Fxyz arrow. Valid values are 1-64.
  • colormx (unsigned int) – The bar plot Mx moment arrow color. Valid values are 1-64.
  • colormy (unsigned int) – The bar plot My moment arrow color. Valid values are 1-64.
  • colormz (unsigned int) – The bar plot Mz moment arrow color. Valid values are 1-64.
  • colormxy (unsigned int) – The color of the Mxy arrow. Valid values are 1-64.
  • colormyz (unsigned int) – The color of the Myz arrow. Valid values are 1-64.
  • colormxz (unsigned int) – The color of the Mxz arrow. Valid values are 1-64.
  • colormxyz (unsigned int) – The color of the Mxyz arrow. Valid values are 1-64.
  • createfield (int) –
    0 - Do not create a nodal displacement field (default)
    1 - Create a nodal displacement field
  • createload (int) –
    0 - Do not create FBD displacement loads (default)
    1 - Create FBD displacement loads
  • declim (int) – The decimal number limit (default 2).
  • display (int) –
    0 - Do not plot FBD displacements
    1 - Plot FBD displacements (default)
  • displacement (int) –
    0 - Applied forces are not participating in the FBD calculation (default)
    1 - Applied forces are participating in the FBD calculation
  • envelope (int) –
    0 - No envelope calculation (default)
    1 - Envelope calculation
  • freenode (int) –
    0 - Free nodes. Find the nodes which are shared by elements other than the elements contained in the freebodysection.
    1 - Boundary nodes. Find only the boundary nodes of the elements contained in the freebodysection.
    2 - All nodes. Find all nodes of the elements contained in the freebodysection.
  • fx (int) –
    Display the Fx forces for bar plots:
    0 - Do not show (default)
    1 - Show
  • fxy (int) –
    Display the Fxy forces for bar plots:
    1 - Show
  • fxyz (int) –
    Display the Fxyz forces for bar plots:
    1 - Show
  • fxz (int) –
    Display the Fxz forces for bar plots:
    1 - Show
  • fy (int) –
    Display the Fy forces for bar plots:
    1 - Show
  • fyz (int) –
    Display the Fyz forces for bar plots:
    1 - Show
  • fz (int) –
    Display the Fz forces for bar plots:
    1 - Show
  • intf (int) –
    0 - Internal forces are not participating in the FBD calculation (default)
    1 - Internal forces are participating in the FBD calculation
  • mpcf (int) –
    0 - MPC forces are not participating in the FBD calculation (default)
    1 - MPC forces are participating in the FBD calculation
  • spcf (int) –
    0 - SPC forces are not participating in the FBD calculation (default)
    1 - SPC forces are participating in the FBD calculation
  • appf (int) –
  • gpf (int) –
    For panel plots only:
    0 - Element forces (default)
    1 - Grid-point forces
  • midarrow (int) –
    0 - Do not show mid arrow (default)
    1 - Show mid arrow
  • minmax (int) –
    0 - Min envelope plot (default)
    1 - Max envelope plot
  • mx (int) –
    Display the Mx moments for bar plots:
    1 - Show
  • mxy (int) –
    Display the Mxy moments for bar plots:
    1 - Show
  • mxyz (int) –
    Display the Mxyz moments for bar plots:
    1 - Show
  • mxz (int) –
    Display the Mxz moments for bar plots:
    1 - Show
  • my (int) –
    Display the My moments for bar plots:
    1 - Show
  • myz (int) –
    Display the Myz moments for bar plots:
    1 - Show
  • mz (int) –
    Display the Mz moments for bar plots:
    1 - Show
  • normalload (int) –
    0 - Do not show normal load (default)
    1 - Show normal load
  • onelems (int) –
    For bar plots only:
    0 - Do not plot on element centroids (default)
    1 - Plot on element centroids
  • onnodes (int) –
    For bar plots only:
    0 - Do not plot on element nodes (default)
    1 - Plot on element nodes
  • plotdir (int) –
    For bar plots only and normalload=1, the plot direction of the normal load:
    0 - Auto (default)
    1 - Global x axis
    2 - Global -x axis
    3 - Global y axis
    4 - Global -y axis
    5 - Global z axis
    6 - Global -z axis
  • resfileid (int) – The result file ID for resultid. Useful when multiple result files are loaded for a single result entity.
  • resultant (int) –
    0 - Free body force/moment plot.
    1 - Resultant force/moment plot.
  • scid (int) – The results subcase ID for result entity specified by resultid.
  • scientific (int) –
    0 - Fixed format text (default)
    1 - Scientific format text
  • showvalue (int) –
    0 - Show value text
    1 - Hide value text (default)
  • sizescale (int) –
    For bar plots only:
    0 - Constant scaling of arrow length (default)
    1 - Magnitude scaling of arrow length
  • stepid (int) – The step/simulation ID for results subcase specified by scid.
  • sumat (int) – Reserved for future development.
  • sysproj (int) – Reserved for future development.
  • tangentialLoad (int) –
    0 - Do not show tangential load (default)
    1 - Show tangential load
  • tolerance (double) – The tolerance to limit the values for the plot creation (default 0.00001).
  • user_sys_id (Entity) – The object describing the system entity.
  • vecstyle (int) –
    For bar plots only:
    0 - 3D style arrow (default)
    1 - 2D style arrow
  • range (int) – Reserved for future development.
  • report_tablename (hwString) – Reserved for future development.
  • rotation (int) – Reserved for future development.
  • resolvein_sys (int) – Reserved for future development.
  • color (int) – Reserved for future development.
  • createtable (int) – Reserved for future development.
  • displayat (int) – Reserved for future development.
  • field_name (hwString) – Reserved for future development.
  • interpolate (int) – Reserved for future development.
  • maxval (double) – Reserved for future development.
  • midarrow – Reserved for future development.
  • summf (int) – Reserved for future development.
  • tangentialLoad – Reserved for future development.
Returns:
Example#
Create a panel plot for panels ID 1, 2, and 3#
import hm
import hm.entities as ent
model = hm.Model()
panels = hm.Collection(model, ent.Panel, [1, 2, 3])
model.hm_fbdplot(
    plot_type="panelplot",
    collection=panels,
    subcase_ids=[[1 1 0], [1 2 0], [2 1 0], [2 1 1]],
    resultid=ent.Result(model, 1),
    scientific=False,
    gpf=0,
    arrlen=75,
    declim=2,
    showvalue=True,
    midarrow=0,
    tangentialload=True,
    normalload=True,
    envelope=False,
    absolute=1,
    minmax=1,
    colorfx=3,
    colorfy=4,
