Model.morphmapdifferencesurf#
- Model.morphmapdifferencesurf(m_collection, f_collection, i_collection, t_collection, r_plane_normal, r_plane_base, rotate, axial, sym, con, blend, mbias, fbias)#
Maps selected nodes from one surface or element collection to the other surface or element collection optionally following the curvature differences (rotate) between the surfaces or element marks and/or mapping about an axis (axis and plane) or using a number of linear mapping options. Note that you can map from a mesh to a surface or surface to a mesh as well as mapping from a mesh to a mesh or a surface to a surface.
Note
This function does not do “True” mapping, that is nodes will not be “fitted” from one surface or element collection to another. Instead, a vector (the plane normal in r_plane) is used to find the target point on the target surface or element collection given a reference point on the initial surface or element collection.
If
blend=1, no fixed nodes have been selected, and no mapped nodes are a part of any domain, this function will automatically assign all non-mapped nodes as fixed nodes.If
blend=2, the blending will only be applied to nodes whichlie along the mesh between the fixed nodes and the mapped nodes.- Parameters:
m_collection (Collection) – The collection containing the mapped node entities.
f_collection (Collection) – The collection containing the fixed node entities.
i_collection (Collection) – The collection containing the initial surface entities or element entities.
t_collection (Collection) – The collection containing the target surface entities or elements entities.
r_plane_normal (hwTriple) – The hwTriple object defining the plane normal components defining the plane for axis rotation. User can also supply a Python list of three doubles.
r_plane_base (hwTriple) – The hwTriple object defining the base point components of the plane for axis rotation. User can also supply a Python list of three doubles.
rotate (int) –
0 - Linear point to point mapping between lines.
1 - Rotate nodes along with curvature difference between lines
axial (int) –
0 - Apply mapping in x, y, z coordinates
1 - Apply mapping about axis defined by r_plane
sym (int) – 0 - Do not use symmetry (only option).
con (int) –
0 - Do not use constraints.
1 - Use constraints
blend (int) –
0 - Do not blend unselected nodes.
1 - Blend all nodes other than mapped and fixed nodes
2 - Blend only nodes on mesh between mapped and fixed nodes
mbias (double) – Bias factor of mapped nodes.
fbias (double) – Bias factor of fixed nodes.
Examples#
Map nodes from one surface collection to another using rotation#import hm import hm.entities as ent model = hm.Model() model.morphmapdifferencesurf( m_collection=hm.Collection(model, ent.Node, [1, 2, 3]), f_collection=hm.Collection(model, ent.Node, [11, 12, 13]), i_collection=hm.Collection(model, ent.Surface, [22, 23]), t_collection=hm.Collection(model, ent.Element, [32, 33, 34, 45, 36]), r_plane_normal=[1.0, 0.0, 0.0], r_plane_base=[1.0, 0.0, 0.0], rotate=1, axial=1, sym=0, con=1, blend=0, mbias=1.0, fbias=1.0, )
Map nodes from one surface collection to an element collection about an axis with no rotation, blending through the mesh, and biasing factors of 2.0#import hm import hm.entities as ent model = hm.Model() model.morphmapdifferencesurf( m_collection=hm.Collection(model, ent.Node, [1, 2, 3]), f_collection=hm.Collection(model, ent.Node, [11, 12, 13]), i_collection=hm.Collection(model, ent.Surface, [22, 23]), t_collection=hm.Collection(model, ent.Element, [32, 33, 34, 45, 36]), r_plane_normal=[1.0, 0.0, 0.0], r_plane_base=[1.0, 0.0, 0.0], rotate=1, axial=0, sym=1, con=1, blend=2, mbias=2.0, fbias=2.0, )
