Model.linestoelementsaddelemsfixed#
Model.linestoelementsaddelemsfixed(collection, elem_size)#
Generates plot elements along selected lines with a given density. These plot elements are then used as feature edges for element remeshing. The use of this function implies that it will be followed by a function that performs meshing/remeshing of elements.
Parameters:
  • collection (Collection) – The collection containing the line entities that should be considered to form feature edges in subsequent element remesh operations.
  • elem_size (double) – The default element edge size used to calculate element densities along the constructed feature edges.
Example#
Remeshe the displayed elements and create feature edges with element size 10.0 along lines with IDs 1600 and 1601#
import hm
import hm.entities as ent
model = hm.Model()
remesh_elems_col = hm.CollectionByDisplayed(model, ent.Element)
model.setusefeatures(mode=1)
# Creating feauture edges plot elements
lines_col = hm.Collection(model, ent.Line, [1600, 1601])
model.linestoelementsaddelemsfixed(collection=lines_col, elem_size=10.0)
# Remeshing
model.defaultremeshelems(
    collection=remesh_elems_col,
    elem_size=3.0,
    elem_type=2,
    elem_type_2=2,
    comp_mode=0,
    size_control=1,
    skew_control=1,
    edge_mesh_type=1,
    min_size=0.0,
    max_size=0.0,
    max_deviation=0.0,
    max_angle=0.0,
    previous_settings=0,
    vertex_angle=30,
