Model.xyplottwocurvemath#
- Model.xyplottwocurvemath(function, outputcurve, xbased)#
Performs a math function on two curves.
- Parameters:
function (int) – The function to be performed (1-6).
outputcurve (hwString) – The name of the output curve.
xbased (int) –
0 - If the function should operate on the y coordinate.
1 - If the function should operate on the x coordinate.
Example#
Perfome a math function on y - coordinate#import hm import hm.entities as ent model = hm.Model() model.xyplottwocurvemath(function=1, outputcurve="curve2", xbased=0)
